couldn't enable NPV mode on MDS 9124 switch
kerim mohammed
Level 3
Level 3
I tried to enable NPV feature on Cisco MDS 9124 switch with image version 3.1(3a) (both kick start and system). however, I couldn't find the "NPV enable". I could see NPIV enable. But no NPV in config mode. any advice?
thanks
it does not need a license, maybe you need to be on 3.3.1a at least
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/compatibility/matrix/featrlis_3x.html
@dynamoxxx
@dynamoxxx
dynamoxxx
Level 5
Level 5
did you try "feature NPV"
@dynamoxxx
@dynamoxxx
it doesn't have that option. am not sure if it requires license.
@dynamoxxx
@dynamoxxx
it looks like that is the issue.But, unfortunately my account won't let me download the images. don't have the privilage.
will try to find a way and will get back to you. thanks!
