01-20-2011 07:53 AM
I am just about to setup my 2 Nexus 5548's in the
lab for VPc. I see that I have to setup an etherchannel using 2 10 gig ports for the Peer link and
I also have to setup a Peer keepalive.
Do I also have to burn a 10 gig port on both switches for this keepalive ?
I dont have any 1 gig ports on these switches.
Cheers
Dave
01-20-2011 01:45 PM
Hi Dave,
You can use the management ports for the keepalive link. They can either be connected back to back, or through a management network.
Chad
01-20-2011 01:52 PM
Thanks Chad, I got it figured out. Swhen I setup the keepalive it defaulted to using the
management VRF that I had created. So all good.
Thanks again.
Dave
05-23-2012 11:12 AM
The best way is to connect the mgmt0 ports to a CORE switch for out of band management. Also, when you configure the vrf context management, make sure you specify a route to the management subnet via vrf management.
