Highlighted
Beginner
DCNM FQDN error
DCNM can only be installed with a FQDN name.
My FQDN is xx-xxx-dcnm-xxx.adm.gnp.les800 but DCNM refuse it.
I need to cheat using:
xx-xxx-dcnm-xxx.adm.gnp.les800.fr or
xx-xxx-dcnm-xxx.adm.gnp.les800.com or
[root@xx-xxx-dcnm-xxx home]# appmgr update network-properties set hostname local xx-xxx-dcnm-xxx.adm.gnp.les800
ERROR: invalid FQDN xx-xxx-dcnm-xxx.adm.gnp.les800
How can I force my FQDN o where is the regex to correct it ????
2 REPLIES 2
Highlighted
Beginner
Re: DCNM FQDN error
appmgr update network-properties set hostname local xx-xxx-dcnm-xxx.adm.gnp.les800 --force
/root/packaged-files/scripts/updateNetworkProperties.sh: unrecognized option '--force'
[root@xx-xxx-dcnm-xxx home]# vi /root/packaged-files/scripts/updateNetworkProperties.sh
Comment line:
#check -is_fqdn "$fqdn" || { echo "ERROR: invalid FQDN $fqdn"; exit 1; }
Can't write cause file is on CD :-/ I need to edit the iso file
Highlighted
Beginner
Re: DCNM FQDN error
SOLUTION:
[root@xx-xxx-dcnm-xxx ~]# mv /root/packaged-files/scripts /root/packaged-files/scripts.tmp
[root@xx-xxx-dcnm-xxx ~]# mkdir /root/packaged-files/scripts
[root@xx-xxx-dcnm-xxx ~]# cp -fr /root/packaged-files/scripts.tmp/* /root/packaged-files/scripts/
[root@xx-xxx-dcnm-xxx ~]# sed -i 's!check -is_fqdn!#check -is_fqdn!g' /root/packaged-files/scripts/updateNetworkProperties.sh
[root@xx-xxx-dcnm-xxx ~]# appmgr update network-properties set hostname local xx-xxx-dcnm-xxx.adm.gnp.les800
[root@xx-xxx-dcnm-xxx ~]# appmgr update network-properties session apply
[root@xx-xxx-dcnm-xxx ~]# rm -fr /root/packaged-files/scripts
[root@xx-xxx-dcnm-xxx ~]# mv /root/packaged-files/scripts.tmp /root/packaged-files/scripts
[root@xx-xxx-dcnm-xxx ~]# reboot
