On the MDS, check your DCNM snmp user's group permissions using the show snmp user command.
If it is anything other than network-admin, run the following command to give your DCNM user admin access:
snmp user YourUsername network-admin
If you continue to have access problems, try removing the non-admin user groups from your user's authority list:
no snmp user YourUsername network-operator
Make sure that your DCNM snmp user has a strong password!!!
If my answers have been helpful in any way, please rate accordingly. Check out my blog for useful vSphere & UCS tips: www.vmtrooper.com
