Highlighted
EISL / TE Port between MDS 9216 and 9124 ?
Dear All ,
I have a MDS 9216 connected to an MDS 9124 . The connected ports are showing as E Ports and not TE ports .
What do I need to do to get them in TE mode of operation .
MDS 9126  fc1/2 --------------------- fc 1/3 MDS 9124
MDS9216# sh int fc 1/2
fc1/2 is up
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:02:00:0d:ec:0c:78:00
    Peer port WWN is 20:03:00:0d:ec:57:cd:00
    Admin port mode is auto, trunk mode is auto
    Port mode is E, FCID is 0x9a0001
    Port vsan is 1
    Speed is 2 Gbps
    Transmit B2B Credit is 16
    Receive B2B Credit is 255
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 144 bits/sec, 18 bytes/sec, 0 frames/sec
    5 minutes output rate 272 bits/sec, 34 bytes/sec, 0 frames/sec
      7751 frames input, 384692 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      7737 frames output, 596996 bytes
      0 input OLS, 1 LRR, 0 NOS, 16 loop inits
      3 output OLS, 3 LRR, 0 NOS, 4 loop inits
      255 receive B2B credit remaining
      16 transmit B2B credit remaining
Software
  BIOS:      version 1.1.0
  loader:    version 1.2(2)
  kickstart: version 2.1(1b)
  system:    version 2.1(1b)
MDS9124# sh int fc 1/3
fc1/3 is up
    Port WWN is 20:03:00:0d:ec:57:cd:00
    Peer port WWN is 20:02:00:0d:ec:0c:78:00
    snmp link state traps are enabled
    Port mode is E
    Port vsan is 1
    Speed is 2 Gbps
    Rate mode is dedicated
    Transmit B2B Credit is 255
    Receive B2B Credit is 16
    5 minutes input rate 296 bits/sec, 37 bytes/sec, 0 frames/sec
    5 minutes output rate 120 bits/sec, 15 bytes/sec, 0 frames/sec
      8921 frames input, 732652 bytes
      8930 frames output, 421396 bytes
      5 input OLS, 6 LRR, 0 NOS, 8 loop inits
      5 output OLS, 2 LRR, 4 NOS, 5 loop inits
      16 receive B2B credit remaining
      255 transmit B2B credit remaining
      254 low priority transmit B2B credit remaining
    Interface last changed at Wed May  9 03:32:24 2012
Software
  BIOS:      version 1.0.12
  kickstart: version 3.2(3)
  system:    version 3.2(3)
Regards ,
Vikas Srivastava
1 ACCEPTED SOLUTION
Highlighted
both the sides are default to trunk mode auto. In this case there will be no trunking, just regular ISL.
Check Table 12-2
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_2_x/san-os/configuration/guide/trnk.html#wpxref31164
Can you configure one side to 'switchport trunk mode on'  under the FC port and check if you can get the link up as TE port?
Thanks, Vin.
4 REPLIES 4
Highlighted
ie is this a new install or you have more vsans defined on the mds switches which you have allowed on the trunk ? what does the trunk config look like ?
from both switches, please get,
show vsan
show run int fc1/2(3)
Thanks, Vin.
Highlighted
Hi Vin ,
Heres the output :
Please note that on both the interfaces i have used the commands "switchport trunk allowed vsan all" but its not showing in the output here .
ICE-MDS9124# sh running-config int fc 1/3
version 3.2(3)
interface fc1/3
  port-license acquire
ICE-MDS9216# sh run int fc 1/2
version 2.1(1b)
interface fc1/2
  no shutdown
ICE-MDS9216# sh vsan
vsan 1 information
         name:VSAN0001  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:up
vsan 500 information
         name:VSAN0500  state:active
vsan 600 information
         name:VSAN0600  state:active
vsan 4094:isolated_vsan
ICE-MDS9124# sh vsan
vsan 1 information
Highlighted
Check Table 12-2
Thanks, Vin.
Highlighted
Thanks Vin , Configuring 'switchport trunk mode on' got as I wanted it to be ...
