Expanding virtual drive
aibrahim.sallam
Beginner
Beginner
Dears,
I have cisco ucs server with the below configuration i need to expand the virtual drive but i don't see available storage on webbios, could someone tell me the steps in details.
Server configration:
Total number of hard disks: 6
Total number of drive group: 2
HDD size: 300
Every drive group have one virtual drive configured raid5 with three hard disks.
I added new hard disk with the same size of the rest hard disks and i need to expand any virtual drive with the new hard disk.
The new hard disk status is unconfigured.
Thank you.
6 Replies 6
padramas
Hello Ahmed,
Server model ? RAID controller model ?
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/raid/configuration/guide/MegaRAID.html#wp1107097
--------- snip ------------
Drives can be added to a drive group only when there is a single virtual drive present on the drive group. If there are multiple virtual drives present on the drive group, the option to add an extra disk is not available.
If could provide the details, I will confirm above statement.
Padma
Thank you for your reply, i attached picture i got it from server check it.
Please see this video for my server i took it.
http://www.icloud.com/photostream/#A9JtdOXmJOujW
Do you get " Expand "  option  in WebIOS utility for Virtual Drive ?
Instructions here
Yes i got it.
gsharma4
Beginner
Beginner
