I attached a drawing to this post so you can see what I am trying to do.
The setup is server at the bottom with dual CNAs each going to separate 2232s. Server communication with the LUNs would be over FCoE. The storage itself up top goes straight into the 5548s using native FC because that is all it supports.
More info: 5ks running with storage license and on version 5.2.1
So, the question will the server be able to use this storage?
Any help finding a How To for this would be much appreciated.
Many thanks as always
P.
