04-30-2013 09:33 AM
I have a Nexus 5548UP switch running version 5.2(1)N1(1b) and a UCS C240 M3S with firmware version 1.4(7b) directly attached via a 10G link (fiber) between the switch port and a UCS VIC P81E in slot 2 of the C240 (Eth 1/32 to port 0 on the P81E).
Any thoughts on why the VIC P81E does not seem to respond to the FIP and then perform a flogi? I assume an operating system on the C240 is not required, however am I wrong here?
Let me know and thanks.
Below is output from interface vfc 20
Message was edited by: Edward Storey More information: As it turns out when I run the command "sh platform software fcoe_mgr info interface vfc 4" there is no appearance of the following event "[FCOE_MGR_VFC_EV_FIP_VLAN_DISCOVERY]". So it appears the FCoE vlan discovery never takes place and so no FIP solicitation. This must be why the state of the vsan continues to be "Vsan 20 is down (waiting for flogi)". I think? Any thoughts?
Message was edited by: Edward Storey So first, I have answered my own question regarding needing an operating system with the correct driver for the Cisco P81E VIC to make this work and the answer is yes. Clearly the P81E cannot produce a flogi to the vsan without a fibre channel software stack loaded. As for the configuration of the switch, it appears I had the correct configuration all along, however what was confusing was the “native vlan” property on the vHBA on the P81E VIC. In some posts the direction was to make it the same as the “native vlan” of the 5548UP Ethernet trunking interface and in at least one document it indicated to use the designated FCoE vlan for the vsan. For my successful test the answer was to use the designated FCoE vlan for the vsan as the “native vlan” property on the vHBA. The only other property I believe I made sure was enabled on the P81E was the “FIP mode”. My test was to try an installation of ESXi 5.0 (VMware-VMvisor-Installer-5.1.0.update01-1065491.x86_64) which, based on other posts, has the correct P81E driver. When the installation came to the point where it was ready to scan for devices I was then able to see the entry in the “flogi database” on the 5548UP. My next test will be to attach an array on the 5548UP and present a LUN from it to see if I can complete the ESXi 5.0 installation. The following command “sh platform software fcoe_mgr info interface vfc 20” was invaluable in understanding the FCoE establishment process on the vfc. When I saw the following event “Triggered event: [FCOE_MGR_VFC_EV_FIP_SOLICITATION]” then the flogi entry showed in the “flogi database”. I have attached another configuration document, since I made a couple of changes to vlan numbers and used a different Ethernet interface. Lastly, I saw the postings regarding the QoS configurations, however from what I can see my system already had the default system QoS configurations for FCoE.
05-01-2013 05:08 PM
I've got a similar problem, I'm running a vFC interface to the 2 ports on the Cisco P81E VIC card.
When I bring up the vFC.. I get 'Interface vFC 116, vsan 1 is down (waiting for flogi).
The vFC is attached to a vPC that includes the FCoE VLANs, the FCoE VLANs are also set on the vHBA properties within CIMC.
05-02-2013 05:21 AM
Could be the FCoE QoS policies aren't applied. What is the ouput of show run ipqos? and show queuing interface e1/32?
05-02-2013 05:07 PM
I was able to get this working.
In my case it was a number of things:
- I was trying to bind the vFC to a vPC port-channel (this worked with NetApp devices but not to the P81E VIC Card)
- Missing the vSAN trunk command on the vFC which I grabbed from yours.. thanks!
- Needed Option ROM on for the P81E Vic Card in BIOS.
- Any configuration changes on the Adapter card requires one or two reboots, be wary of the 'configuration pending'.
- FIP Mode enabled, NIV disabled (see below).
The QoS policies Jeremy alludes to had bitten me in the past so in that respect I was fine.
At some stage during the troubleshooting I got the impression I might need to install the virtualization feature set on the 5Ks to create vEthernet ports - but no, you only need this (and NIV mode) if you want to use more than the default adapters: vNIC1, vNIC2 and FC0 and FC1.
Note: The adapter firmware in my case is 2.1(1a) - I also tried with 2.1(0.367f) which also worked.
Hope ths helps.
