FM : How to delete a zone on MDS 9513
vt351j
Hi - can any one verify if below steps are ok, to delete a zone using FM.
open Fabric Manager Application "{password}".
Select "appropriate fabric"  and select open.
expand vsan101
Right Click VSAN001 for "appropriate switch" switch.
select "Edit Local Full Zone Database..."
### Zones###
Expand "ZoneSets"  list.
Select Zone Name from drop down list. and Right Click and Select "delete"
Ensure "zone_name"  is chosen and press the "Activate" button at the bottom.
                Select "Yes" to review"
                Check "Save Running"
                Click "Continue Activation"
                Monitor output messages.
Close Open windows and "save running Config" .
press the "Distribute" button at the bottom.
2 Accepted Solutions
dynamoxxx
Level 5
Level 5
that looks correct to me.
@dynamoxxx
dynamoxxx
Level 5
Level 5
@dynamoxxx
Agreed
