8704
dennis.dai
Beginner
half duplex or full duplex configuration for MDS9124 management port?
Hi All,
Is it possible to set the management port of mds 9124 about half or full duplex configuration?
I want to correct following error:
Jun 13 10:27:20.799 GMT: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet4/18 (not half duplex), with mtw1pc02bs0(FOX1450G8QG) mgmt0 (half duplex).
it seems mds 9124 set his port to half duplex.
Dennis
2 ACCEPTED SOLUTIONS
deschamps
Beginner
You may want to check this thread :
https://supportforums.cisco.com/thread/2059109
Else try the following :
switch# config terminal
switch(config)#
switch(config)# interface mgmt0
switch(config-if)# switchport duplex full
switch(config)# exit
switch#
switch# copy running-config startup-config
Also, I would suggest you check what the counterpart of your MDS switch mgmt interface is set to (i.e. is it set to autoneg, then try setting it to fix speed/duplex or the other way around).
Vincent Jamart
Hi Dennis,
You might have hit bug CSCte76880 (http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte76880)
Configure both interfaces to auto duplex achieve a full duplex connection as a workaround, or upgrade to 4.2(7e) or 5.0(4d) where the fix has been integrated.
Best Regards,
Vincent
4 REPLIES 4
deschamps
Beginner
switch(config)#
switch#
Vincent Jamart
Hi Dennis,
Best Regards,
Vincent
Kris Vandecruys
Hi Dennis,
is there a reason you're not using auto detect?
Hi Kris,
Becasue network admin told me that he got the error message:
Best Regards,
Dennis
Content for Community-Ad
