10-03-2003 03:41 PM
What is the command to add multiple zones to a zoneset?
Solved! Go to Solution.
10-06-2003 12:28 PM
There are few ways- sample of one of it is below
From the cli,
9509# conf t
9509(config)# zone name cisco vsan 1
9509(config-zone)# member ?
domain-id Add member based on domain-id,port-number
fcalias Add fcalias to zone
fcid Add FCID member to zone
fwwn Add Fabric Port WWN member to zone
interface Add member based on interface
pwwn Add Port WWN member to zone
symbolic-nodename Add Symbolic Node Name member to zone
9509(config-zone)# member pwwn 01:11:11:11:11:11:11:11
9509(config-zone)# exit
9509(config)# zone name cisco1 vsan 1
9509(config)# zoneset name test vsan 1
9509(config-zoneset)# member cisco
9509(config-zoneset)# member cisco1
9509(config-zoneset)# exit
9509(config)# exit
9509# sh zone
zone zoneset
9509# sh zoneset
9509#
You can also use Fabric Manager to create and add zoneset. Also you have to activate the zoneseat to be effective...
Here is the URL for your ref..for software rel. 1.2.1
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/1_2/sw_confg/zonecnfg.htm#24151
Hope this helps..
10-03-2003 04:26 PM
What platform you are looking for to add zones to zoneset.... MDS or SN series..
10-06-2003 10:22 AM
Adding zones to zonesets on an MDS 9216.
10-06-2003 12:28 PM
From the cli,
9509# conf t
9509(config)# exit
9509# sh zone
zone zoneset
9509# sh zoneset
9509#
Hope this helps..
