how to backup a "show tech" and a "running config" from MDS switches
ivy_yangxiaohua
Beginner
Beginner
hi, guys
I am a newbie of MDS switches.
but I got a request this week asking me to actively backup a "show tech" and a "running config" from the MDS switches........
so my questions are:
1) if I want to back up MDS configurations, which commnds should I run? or just "show tech" is enough?
2) is the MDS itself have the backup function? for example can ftp the configuration to someplace?
please help point me the right direction or is there any official referece docs I can refer to ?
thanks in advance!!!
2 Accepted Solutions
dynamoxxx
Contributor
Contributor
1) to backup MDS configuration you want to run this command:
copy running-config
and then you have multiple options where you can send it to for example you could tftp it
copy running-config tftp://yourftpserver/mdsbackup.txt
2) i don't believe there is a native solution that performs scheduled backups but it's say easy to write a little bash/perl script.
@dynamoxxx
@dynamoxxx
There is an example of a scheduled backup here on page 1-15 (adobe page 31)
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/cookbook/MDScookbook31.pdf
David
16 Replies 16
dynamoxxx
Contributor
Contributor
copy running-config
@dynamoxxx
@dynamoxxx
Thank you so much dynamoxxx! so the current problem is how to schedulely run this command on the MDS.......but I don't believe there is crontab on the MDS. May need to use expect to log in MDS automactically and run the command to back up the mds config to a target location.
David
Thank you so much dakester! This is exactly what I am looking for!! I will try it on our environment next week.
problem that i have with using automated scheduler from MDS, you can't add any error checking. If your tftp server is down you will not get any alerts, you will think backups are happening but in reality a change on your tftp server broke your backup strategy.
@dynamoxxx
@dynamoxxx
thanks for your kindly reminder Dynamoxxx
I cured the "no backup happened" by running a script (assuming your tftp is linux/unix) via crontab that checks for a file with the right name and >0 bytes (actually went to higher number after some use history)
yeah, that's right, we indeed can monitor the file size on the target tftp location.......
but my current issue is that switch can't connect with my tftp server.......
I just pick up a linux box of the same network section as tftp server....so there is no firewall blocking
but not sure if I need to make some tftp configuration on this linux box.....
so I am still digging~~~
lasfswcor01(config)# copy startup-config  tftp://10.119.9.90/home/iyang
Trying to connect to tftp server......
Connection to server Established. Copying Started.....
TFTP put operation failed:Connection timed out
I want to use scp way since it uses TCP and requires 22 port only.
but scp requires login usename and password, so it is interactive way ...
so I am wondering if I can put both username and password in the command line?
then I can use Scheduler for scp way.........
lasfswcor01# copy startup-config scp://root@10.119.9.90/home/iyang
The authenticity of host '10.119.9.90 (10.119.9.90)' can't be established.
RSA key fingerprint is 69:d0:55:fe:db:fd:79:7a:65:94:dc:d6:cc:15:e4:75.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '10.119.9.90' (RSA) to the list of known hosts.
root@10.119.9.90's
password:
lasfswcor01-startup-config        100%  727KB 727.4KB/s   00:00
after configure the tftp server now I can backup our mds config via tftp+scheduler now!!!
thanks everybody for your help!!
really appreciate for your help!!
Is there a way to schedule a job using FTP instead of TFTP. If I use this command by itself, without the scheduler, it prompts for a password ( copy startup-config ftp://10.1.1.1/MDS_Bkup/DowMDS_$(TIMESTAMP).txt ) . When I try to use the scheduler, it doesn't work. How can I input username and password into command? I also used below and that didn't work.
ip ftp username user
ip ftp password password
can you use tftp or sftp as your backup target ?
@dynamoxxx
@dynamoxxx
tftp worked for me but not ftp. My ftp requires a password and I don't know how to send it via scheduler job.
Worked:
scheduler job name BkupConfig
  copy running-config startup-config
  copy startup-config tftp://10.1.1.1/MDS_Bkup/DowMDS$(TIMESTAMP).txt
scheduler schedule name Weekly_5am
  job name BkupConfig
  time weekly 01:05:00
FAILED FTP:
Job Name       : test                              Job Status: Success (0)
Schedule Name  : test                              User Name : user
Completion time: Thu Sep  5 11:08:41 2013
--------------------------------- Job Output ---------------------------------
`copy running-config startup-config`
[###                                     ]   6%
[######                                  ]  12%
[########                                ]  19%
[###########                             ]  25%
[##############                          ]  32%
[################                        ]  39%
[###################                     ]  45%
[######################                  ]  51%
[########################                ]  59%
[###########################             ]  65%
[#############################           ]  71%
[################################        ]  79%
[###################################     ]  85%
[#####################################   ]  91%
[########################################]  98%
[########################################] 100%
Copy complete, now saving to disk (please wait)...
`copy startup-config
ftp://user@10.1.1.1/MDS_Bkup/DowMDS2013-09-05-10.53.05.txt
Password: Login failed.
old thread, i know.... but to pre-load the credentials for the scheduled FTP job, use
ip ftp username kewldude
ip ftp password P@ssword1
So I labbed this up and if you have service password-encryption enabled, the password is encrypted with the sucky '7' style hashing. However, just make sure this password is only used for this function. Will prevent shoulder surfers. Additionally, make sure the FTP user only has write capability.
It should be noted that FTP isn't encrypted in transit but it's still better than TFTP.
This is cool because Windows doesn't have a built in TFTP function, but you can add an FTP server. Additionally, IIS lets you restrict the IP addresses that can access
Recognize Your Peers
