How to monitor only certain ports for up/down?
reedk-cma
I apologize if this is an elementary question, but I want to monitor (via SNMP or SMTP) events like these:
2010 Jun 14 03:03:54 xsmiahczc02A %PORT-5-IF_DOWN_OLS_RCVD: %$VSAN 100%$ Interface fc5/1 is down (OLS received)
2010 Apr 23 21:37:56 xsmiahczc02A %PORT-5-IF_DOWN_NOS_RCVD: %$VSAN 101%$ Interface fc5/43 is down (NOS received)
2010 Apr 23 21:37:56 xsmiahczc02A %PORT-5-IF_UP: %$VSAN 101%$ Interface fc5/43 is up in mode F
on _some_ ports but not _all_ ports. Specfically, I do not want to be informed of every host that goes up or down, but I DO want to know if a storage port goes offline. So I am looking for a way to trap and alert up/down conditions only on certain ports.
Is there a way to do this? I am using MDS95xx running 4.2(1b).
dynamoxxx
Level 5
Level 5
you could disable link-state-trap for all ports except the ones where arrays are connected to
Command
Purpose
Step 1
switch# config t
switch(config)#
Enters configuration mode.
Step 2
switch(config)#interface bay 6
Specifies the interface on which to disable SNMP link-state traps.
switch(config-if)# no link-state-trap
Disables SNMP link-state traps for the interface.
switch(config-if)# link-state-trap
Enables SNMP link-state traps for the interface.
@dynamoxxx
