I have 2 Nexus 5548UP in Active-Active mode, is it possible to switch 1 of these (Nexus 5548UP-B) and replace it with the new Nexus 56128P?
Below are my high level steps in mind:
1. Backup the configuration of Nexus 5548UP-B
2. Bring down Nexus 5548UP-B
3. Switch Nexus 56128P
4. Load the configuration from Nexus 5548UP-B to Nexus 56128P
Thank you so much in advance!
Solved! Go to Solution.
Jasme,
When you say Active-Active, are you referring to Nexus' vPC technology? If so, you cannot swap one model for the other as this will pose vPC inconsistencies and the PL will more than likely not come up among other things.
Hope that helps.
- Andrea
Jasme,
Hope that helps.
- Andrea
