How to replace Nexus 5548UP to Nexus 56128P
I have 2 Nexus 5548UP in Active-Active mode, is it possible to switch 1 of these (Nexus 5548UP-B) and replace it with the new Nexus 56128P?
Below are my high level steps in mind:
1. Backup the configuration of Nexus 5548UP-B
2. Bring down Nexus 5548UP-B
3. Switch Nexus 56128P
4. Load the configuration from Nexus 5548UP-B to Nexus 56128P
Thank you so much in advance!
Andrea Testino
Jasme,
When you say Active-Active, are you referring to Nexus' vPC technology? If so, you cannot swap one model for the other as this will pose vPC inconsistencies and the PL will more than likely not come up among other things.
Hope that helps.
- Andrea
- Andrea, CCIE #56739 R&S
Andrea Testino
Jasme,
Hope that helps.
- Andrea
Hi Andrea,
Thank you very much for your response.
May I ask if there are no compatibility issues between 5548UP and 56128P? Can we readily load the configuration from 5548UP?
Thanks again.
