I can't stop a process in MDS
I need to kill a proccess in a switch MDS 9706 because this didn't allow me to delete a user.
When I try to delete the user, appears the next:
user monitoring is currently used by process 22840
I check what proccess it is using:
PID State PC Start_cnt TTY Type Process
22840 S f65cbf67 1 0 O vsh
I stopped the services that I know the user is using, but nothing it happens. I try to use the command kill but it didn't work.
Thanks.
Branden Varney
   In what context did you use the kill command? Do you have the output?
You will most likely need to open a case with TAC to get help killing this process.
Branden Varney
Hi Branden,
Yes, I opened a TAC case and they helped us to access a linux mode in which we was able to kill the process.
Thanks for your help. Sorry for delay in answering but we haven't received a notification from your answer.
Kind Regards!
