MDS 9509 Failover Testing failed
troelala01
We tried to do a failover to test the HA environment for the upcoming upgrade to 2.0(1b), only with no succes. We're currently running on 1.2(1b) and want to upgrade non-disruptively to the new firmware.
can anybody tell me what went wrong? Thanks in advance.
Switch CLI Output:
SSW-97-001# show module
Mod Ports Module-Type Model Status
1 16 1/2 Gbps FC Module DS-X9016 ok
2 16 1/2 Gbps FC Module DS-X9016 ok
3 16 1/2 Gbps FC Module DS-X9016 ok
4 16 1/2 Gbps FC Module DS-X9016 ok
5 0 Supervisor/Fabric-1 DS-X9530-SF1-K9 active *
6 0 Supervisor/Fabric-1 DS-X9530-SF1-K9 ha-standby
Mod Sw Hw World-Wide-Name(s) (WWN)
1 1.2(1b) 3.0 20:01:00:0d:ec:02:34:80 to 20:10:00:0d:ec:02:34:80
2 1.2(1b) 5.0 20:41:00:0d:ec:02:34:80 to 20:50:00:0d:ec:02:34:80
3 1.2(1b) 5.0 20:81:00:0d:ec:02:34:80 to 20:90:00:0d:ec:02:34:80
4 1.2(1b) 5.0 20:c1:00:0d:ec:02:34:80 to 20:d0:00:0d:ec:02:34:80
5 1.2(1b) 4.0 --
6 1.2(1b) 4.0 --
Mod MAC-Address(es) Serial-Num
1 00-0c-30-da-09-6c to 00-0c-30-da-09-70 JAB0749066Y
2 00-0c-30-da-2c-88 to 00-0c-30-da-2c-8c JAB075107B2
3 00-0c-30-da-2c-60 to 00-0c-30-da-2c-64 JAB075107FW
4 00-0c-30-da-78-38 to 00-0c-30-da-78-3c JAB08040ACU
5 00-0c-30-d9-f5-60 to 00-0c-30-d9-f5-64 JAB0747055Q
6 00-0c-30-d9-f4-d0 to 00-0c-30-d9-f4-d4 JAB0747059P
* this terminal session
SSW-97-001# conf t
Enter configuration commands, one per line. End with CNTL/Z.
SSW-97-001(config)# system switchover warm
SSW-97-001(config)# exit
6 0 Supervisor/Fabric-1 DS-X9530-SF1-K9 standby
5 1.2(1b) 4.0 --
6 1.2(1b) 4.0 --
troelala01
Some log messages:
Feb 11 01:17:39 switch1.int.bon.nl : Feb 11 02:17:38 cet: %KERN-2-SYSTEM_MSG: mts: HA communication with standby timedout
Feb 11 01:17:39 switch1.int.bon.nl : Feb 11 02:17:39 cet: %PLATFORM-5-MOD_REMOVE: Module 6 removed
Feb 11 01:17:41 switch1.int.bon.nl : Feb 11 02:17:41 cet: %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configuring console from pts/0 (192.168.44.1)
Feb 11 01:17:49 switch1.int.bon.nl : Feb 11 02:17:49 cet: %SYSMGR-3-OPERATIONAL_MODE_WARM: Operational redundancy mode set to warm (error-id 0x401E0017).
Feb 11 01:17:53 switch1.int.bon.nl : Feb 11 02:17:53 cet: %MODULE-5-STANDBY_SUP_OK: Supervisor 6 is standby
From config mode you only enable and disable switchover, you actulay initiate it from exec mode. But I may be wrong. Anyhow I use it from exec mode without a problem.
You are correct, we did it wrong. We tested it last night with succes.
