Hello Community,
I tried to describe my issue through the title of this discussion. I have a problem in regards to the connection between the MDS Switches and Nexus Switches at a Customers Data Center. So far we have configured our Ports in this way:
1) Nexus is in NPV Mode, port to MDS is in NP Mode, Trunking is off
2) MDS is in its Default Mode(IDK what it's called, sorry), I have zones configured in it, and the port to the Nexus Switch is configured as an F port, with trunking off.
Normally in this case the Nexus Switch should get the WWNs from all the Hosts and Storages "advertised" through it's NP port, but it's seeing none of them. Here is the show interface command:
MDS:
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:02:00:3a:9c:ca:44:e0
Admin port mode is F, trunk mode is off
snmp link state traps are enabled
Port mode is F, FCID is 0x720000
Port vsan is 400
Admin Speed is auto
Operating Speed is 8 Gbps
Rate mode is dedicated
Port flow-control is R_RDY
Transmit B2B Credit is 16
Receive B2B Credit is 64
B2B State Change: Admin(on), Oper(down)
Receive data field Size is 2112
Beacon is turned off
Logical type is edge
5 minutes input rate 0 bits/sec,0 bytes/sec, 0 frames/sec
5 minutes output rate 0 bits/sec,0 bytes/sec, 0 frames/sec
60 frames input,4792 bytes
0 discards,0 errors
0 invalid CRC/FCS,0 unknown class
0 too long,0 too short
100 frames output,14112 bytes
0 discards,0 errors
0 input OLS,0 LRR,1 NOS,0 loop inits
9 output OLS,6 LRR, 2 NOS, 0 loop inits
64 receive B2B credit remaining
16 transmit B2B credit remaining
16 low priority transmit B2B credit remaining
Interface last changed at Wed Feb 17 16:43:13 2021
Last clearing of "show interface" counters : never
Nexus:
fc1/24 is up
Port WWN is 20:18:00:2a:6a:98:a0:40
Admin port mode is NP, trunk mode is off
Port mode is NP
Port vsan is 400
Speed is 8 Gbps
Transmit B2B Credit is 64
Receive B2B Credit is 16
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
485 frames input, 40324 bytes
46 discards, 3 errors
0 CRC, 0 unknown class
0 too long, 0 too short
358 frames output, 29112 bytes
0 discards, 0 errors
48 input OLS, 48 LRR, 90 NOS, 0 loop inits
96 output OLS, 3 LRR, 51 NOS, 0 loop inits
last clearing of "show interface" counters never
16 receive B2B credit remaining
64 transmit B2B credit remaining
0 low priority transmit B2B credit remaining
Interface last changed at Mon Feb 15 14:46:53 2021
drc-nexsw-01# sh run int fc1/24
!Command: show running-config interface fc1/24
!Time: Mon Feb 15 15:13:44 2021
version 7.3(5)N1(1)
interface fc1/24
switchport mode NP
no shutdown
On the MDS Side, I can see the pWWN of the Nexus Switch, but the Nexus Switch isn't even seeing the MDS. Do you guys have had any experience like this and how can I solve it?
Best,
Atdhe
Is NPIV enabled on MDS?
switch(config)# npiv enable
Kirk...
I enabled the feature through: feature npiv
I will check for the npiv enable command, if that is necessary too and I'll reply if that solved the problem.
Best,
Atdhe
ok so this is the output:
