MDSSTR23 %NPV-5-FRAME_DISCARDED: %$VSAN 1%$ Frame with unexpected FC2 status 0xc received on interface ext2
jjpeyrache
Level 5
Level 5
hello
Customer reported these error messages on 2X Mds9124e
reproducible every 28minutes, even if MDS system message and recovery
say no action (below extract)
how to fix this issue because syslog files and log files are full rapidly
thanks in advance
JYP
Error Message     NPV-5-FRAME_DISCARDED: [chars]
Explanation    NPV process discarded an FC2 frame.
Recommended Action    No action is required.
lmn20176
We had this problem with the nexus 5K connected to the MDS9124.  It's because of VSAN1.
I think if you don't use vsan1, then things will be fine.
AND also, the MDS 91x4 don't support F port trunking.
although we don't use vlan 1 we got the same message every 20 minutes on some interfaces
%NPV-5-FRAME_DISCARDED: %$VSAN 998%$ Frame with unexpected FC2 status 0xc received
I enabled some debug to find out senders source of these frame by using:
  • debug npv errors vsan 999
  • debug npv events vsan 999
  • debug fc2 error vsan 999 interface fc2/2
    But the onyl additional info I got was:
2012 Nov 29 09:34:27.335338 npv: npivp_fc2_msg_recv: Unknown fc2 status 12
What debug I've to use to find out the source?
