Highlighted
Beginner
N7K mixing F2E and M1 card in the same default VDC
I read an update stating that after version 6.2 in the N7K that F2E and M1 cards can be mixed in the same VDC. I am running version 6.2.(8a). Only the ports for the M1 card are available and I tried add the ports from the F2 cards to vdc 1 and its says its not supported. I know the only way I was able to get this to work by creating a separate VDC for the F card and leaving the M card in VDC1. The customer doesn't plan to use any VDC's only needs L3 functionality and L2 functionality to segment any non L3 ports into VLANs. What can I do to make sure the ports from the F2 cards are available to use.
switch(config-vdc)# allocate interface e2/1-48
Moving ports will cause all config associated to them in source vdc to be removed. Are you sure you want to move the ports (y/n)?  [yes] yes
ERROR: 1 or more interfaces are from a module of type not supported by this vdc
switch(config-vdc)#
I have a N7K with these cards:
Mod  Ports  Module-Type                         Model              Status
1    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
2    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
3    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
4    48     1/10 Gbps BASE-T Ethernet Module    N7K-F248XT-25E     ok
5    0      Supervisor Module-2                 N7K-SUP2E          active *
6    0      Supervisor Module-2                 N7K-SUP2E          ha-standby
Mod  Sw              Hw
1    6.2(8a)         1.5
2    6.2(8a)         1.2
3    6.2(8a)         1.2
4    6.2(8a)         1.2
5    6.2(8a)         1.1
6    6.2(8a)         1.1
switch# show vdc member
Flags : b - breakout port
vdc_id: 0 vdc_name: Unallocated interfaces:
        Ethernet2/1           Ethernet2/2           Ethernet2/3
        Ethernet2/4           Ethernet2/5           Ethernet2/6
        Ethernet2/7           Ethernet2/8           Ethernet2/9
        Ethernet2/10          Ethernet2/11          Ethernet2/12
        Ethernet2/13          Ethernet2/14          Ethernet2/15
etc..
vdc_id: 1 vdc_name: switch interfaces:
        Ethernet1/1           Ethernet1/2           Ethernet1/3
        Ethernet1/4           Ethernet1/5           Ethernet1/6
        Ethernet1/7           Ethernet1/8           Ethernet1/9
        Ethernet1/10          Ethernet1/11          Ethernet1/12
        Ethernet1/13          Ethernet1/14          Ethernet1/15
(only shows ports for the M card)
switch# show vdc detail
Switchwide mode is m1 f1 m1xl f2 m2xl f2e f3
vdc id: 1
vdc name: switch
vdc state: active
vdc mac address: 00:26:98:23:5b:c1
vdc ha policy: RELOAD
vdc dual-sup ha policy: SWITCHOVER
vdc boot Order: 1
CPU Share: 5
CPU Share Percentage: 100%
vdc create time: Fri Jan  8 09:57:30 2016
vdc reload count: 0
vdc uptime: 0 day(s), 22 hour(s), 58 minute(s), 58 second(s)
vdc restart count: 0
vdc type: Ethernet
vdc supported linecards: m1 f1 m1xl m2xl
switch#
switch#
switch#
switch# show inter bri
Port   VRF          Status IP Address                              Speed    MTU
mgmt0  --           down   --                                      --       1500
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Por
t
Interface        Ch
Eth1/1        --      eth  routed up      none                       1000(D) --
Eth1/2        --      eth  routed down    Administratively down      auto(D) --
Eth1/3        --      eth  routed down    Administratively down      auto(D) --
Eth1/4        --      eth  routed down    Administratively down      auto(D) --
Eth1/5        --      eth  routed down    Administratively down      auto(D) --
etc..
Eth1/48       --      eth  routed down    Administratively down      auto(D) --
Interface Secondary VLAN(Type)                    Status Reason
Vlan1     --                                      down   Administratively down
switch#
1 REPLY 1
Highlighted
F2e can do layer 3 only if it's in a VDC without M cards. Check out the supported functions on this matrix. It just doesn't mention that you can't mix the F2e with M for layer 3 to work.
http://www.cisco.com/c/en/us/products/switches/nexus-7000-series-switches/models-comparison.html#~tab-c
