Highlighted
Beginner
Nexus 5500 and FEX Port-channel
Team,
I have been starting to read a lot of this tech but I still have some doubts regarding port-channel limits in my platform.
So this is my current set up:
- 1 Nexus N5K-C5596UP
- 2 Fabric Extenders N2K-C2148T-1GE.
Currently  the Fabric Extenders are connected to the C5596UP, and they have been  attached correctly, and everything is working fine:
LAB# show fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
110        FEX0100                Online      N2K-C2148T-1GE   FOX123455666
120        FEX0200                Online      N2K-C2148T-1GE   FOX123123234
I have been reading this DOC:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572829-01_Design_N5K_N2K_vPC_DG.pdf
There I read that:
- There are differences between Nexus 5000 and 5500 mostly because port density of 5500.
- There are something called "index" which have a limitation of 48.
- In 5500 every single port can be a port-channel itself.
- Those index can be used either by using a single port, several ports or bundles of ports.
- If the nexus use one of their hardware ports it will use one index.
- On the other hand, If the nexus doesnt use its hardware ports, It won't use those index.
- The document also describes that if the port-channel just use FEX ports, it won't use an index.
I also read this document that describes limitations of interfaces per bundle up to 16.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration_limits/limits_502/b_Cisco_Nexus_5000_Series_Configuration_Limits_for_Cisco_NX_OS_Release_502_n1_1.html
So after of read that I still have some questions:
1. If I configure port-channels just using fex ports, I wont use indexes but, there are still limitations on it?.
2. How many port-channels can be configured on a single FEX?
3. How many port-channels can be configured if I am using ports that belongs to diferent FEX?.
4. How many port-channels can be configured using hardware ports?
5. How can I check how many available indexes left?
6. There is a limitation of port-channels based on version?
7. 16 ports as limit applies to every port-channel configured?
Thank you for all your support.
Pablo.
Everyone's tags (6)
