Is there a way to show from the CLI whether the switch is a 5548P or 5548UP ?
I have seen the physical labeling but wanted to a way to verify via the CLI.
Solved! Go to Solution.
You can run the "show inventory" command and it should show you what you need. You can also try "show version" but I don't think it shows up in that output.
Okay I see it now under PID...that was easy.
Thanks!
