Nexus 5596UP - Verify Fiber Channel Licensing
dvaggalis
The "show license usage" Show Command, shows you whether the FC/storage licensing is enabled, but it does not indicate how many ports are supported.  Is there a way to show this?
N5K-2# show license usage
Feature                     Ins Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                 No   -   Unused             -
FM_SERVER_PKG                 No   -   Unused             -
ENTERPRISE_PKG               Yes   -   Unused Never      -
FC_FEATURES_PKG               Yes   -   In use Never       -
VMFEX_FEATURE_PKG             No   -   Unused             -
ENHANCED_LAYER2_PKG           No   -   Unused             -
LAN_BASE_SERVICES_PKG         No   -   Unused             -
LAN_ENTERPRISE_SERVICES_PKG   No   -   Unused             -
N5K-2#
jihicks
All the Fibre Channel features of the Cisco Nexus device are packaged in the FC Plugin. When you enable FCoE, the switch software checks for the FC_FEATURES_PKG license. If it finds the license, the software loads the plugin. If the license is not found, the software loads the plugin with a grace period of 180 days.
After the FC Plugin is loaded, the following occurs:
    All Fibre Channel and FCoE related CLI are available
    The Fibre Channel interfaces of any installed Expansion Modules are available
Best regards,
Jim
