09-30-2013 02:58 AM
I am having trouble with distributing my zone config between 5Ks.
my zone status is as follows:
VSAN: 20 default-zone: deny distribute: full Interop: default
mode: basic merge-control: allow
session: none
hard-zoning: enabled broadcast: disabled
Default zone:
qos: none broadcast: disabled ronly: unsupported
Full Zoning Database :
DB size: 984 bytes
Zonesets:1 Zones:7 Aliases: 0
Active Zoning Database :
DB size: 500 bytes
Name: nexus-a-switches Zonesets:1 Zones:7
Status: Activation completed at 16:57:25 GMT Sep 25 2013
I wanted to enable the zone distribution feature as listed here:
like this:
Enabling Full Zone Set Distribution
All switches in the Cisco Nexus 5000 Series distribute active zone sets when new E port links come up or when a new zone set is activated in a VSAN. The zone set distribution takes effect while sending merge requests to the adjacent switch or while activating a zone set.
To enable full zone set and active zone set distribution to all switches on a per VSAN basis, perform this task:
09-30-2013 07:16 PM
Hello Jonathan,
Change your zone mode to enhanced and you zone config will be distributed through the fabric.
10-01-2013 01:04 AM
Thanks Richard,
I did see this and thought it may be the answer.
My question is around the impact of this. The hosts and SAN are in production use and I need to know if I need to plan any downtime to make the change?
Also I read there was no easy rollback from enhanced zoning, is this true?
10-01-2013 06:19 AM
The changing to enhanced mode is disruptive, you need a window maintenace to do this.
About the the roolback to the basic mode, it's easy if you want the same full zone and active in all fabric. Taking into consideration you are not using specific enhanced mode features, only the zone distribution.
