Nexus 6001 native FC
Matt_Rogerson
Does the Nexus 6001 support native FC?  I'm having issues changing the port type;
 show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support:
http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
 BIOS:      version 1.5.0
 loader:    version N/A
 kickstart: version 7.0(5)N1(1)
 system:    version 7.0(5)N1(1)
 Power Sequencer Firmware:
            Module 1: version v4.0
            Module 2: version v4.0
 Fabric Power Sequencer Firmware: Module 1: version v4.0
 Microcontroller Firmware:        version v1.2.0.5
 QSFP Microcontroller Firmware:
            Module 2: v1.3.0.0
            Module 1: v1.1.0.0
 BIOS compile time:       12/29/2012
 kickstart image file is: bootflash:///n6000-uk9-kickstart.7.0.5.N1.1.bin
 kickstart compile time:  10/29/2014 22:00:00 [10/30/2014 11:46:56]
 system image file is:    bootflash:///n6000-uk9.7.0.5.N1.1.bin
 system compile time:     10/29/2014 22:00:00 [10/30/2014 11:47:58]
Hardware
 cisco Nexus 6001 Chassis ("Nexus 64 Supervisor")
 Intel(R) Xeon(R) CPU  @ 2.00 with 8238120 kB of memory.
 Processor Board ID FOC181506P3
  Device name: xxxxxxxxxxxxxx
 bootflash:    7823360 kB
Kernel uptime is 3 day(s), 17 hour(s), 25 minute(s), 49 second(s)
Last reset at 642096 usecs after  Fri Feb 27 15:24:40 2015
  Reason: Disruptive upgrade
 System version: 6.0(2)N2(3)
 Service:
plugin
 Core Plugin, Ethernet Plugin, Fc Plugin
xxxxxx# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
xxxxxx(config)# slot 1
xxxxxx# port 47-48 type fc
ERROR: Module type doesn't support this CLI
Any help would be appreciated.  Thanks
Walter Dey
Hi Matt
do cli "feature fcoe" and it should work
https://supportforums.cisco.com/discussion/12331541/nexus-56128p-fibre-channel-interface
Walter.
Sorry, should have mentioned that I'd already enabled feature fcoe;
xxxxx(config)# show feature
Feature Name          Instance  State
Flexlink              1         disabled
amt                   1         disabled
bfd                   1         disabled
bfd_app               1         disabled
bgp                   1         disabled
bulkstat              1         disabled
cable-management      1         disabled
cts                   1         disabled
dhcp                  1         disabled
dot1x                 1         disabled
eigrp                 1         disabled
eigrp                 2         disabled
eigrp                 3         disabled
eigrp                 4         disabled
eth_port_sec          1         disabled
evmed                 1         disabled
extended_credit       1         disabled
fabric-access         1         disabled
fabric-binding        1         disabled
fabric_mcast          1         disabled
fc-port-security      1         disabled
fcoe                  1         enabled
xxxxxxxxx(config)# slot 1
xxxxxxxxx(config-slot)# port 47-48 type fc
Have you seen
https://supportforums.cisco.com/discussion/12023391/converting-eth-port-fc-port-cisco-6001-switch
Expansion Modules
Expansion modules allow the Cisco Nexus 6004 switch to be configured as cost-effective 10/40-Gigabit Ethernet switches
and as I/O consolidation platforms with native Fibre Channel connectivity.
Thanks for your replies, Walter.
I have seen that post, yes.  The Cisco guy who replied stated that Cisco were hoping to introduce support for native FC sometime last year.  I can only assume this hasn't happened yet, or only for the 6004.
