02-21-2014 07:31 PM
can someone tell me if the attached diagram is supported? i am having issues getting the fc connection funtioning from the host hba to the brocade fabric.
02-21-2014 07:34 PM
03-20-2014 07:38 AM
AFAIK that configuration is not supported. Even if it were technically feasible, no storage vendor would support that architecture.
Rgds
03-03-2014 12:11 PM
I do not think you can have cascaded NPV switches connected to a NPIV switch. Again I would have to defer
From the below doc it says :
Connectivity from an FCoE NPV bridge to the FCF is supported only over point-to-point links."
Hope this helps.
~upinder
03-21-2014 09:51 AM
Nested NPV not supported. Even with UCS FI, we always want NPV - NPIV to work point to point and have the FI's directly connected to the SAN switch and provide flogi/DCID services.
Cheers,
-amit singh
