Nexus Swith 5548UP FCOE(VFC) not found in Show flogi database any config missing ?
Ariq Ibne Aziz
HI,
Im not good at configuring N5k, i have configured one before. that worked fine. but right now im facing little problem.
I have configured the n5k  Dell complent stroage(FC) and Dell Power edge R730 (CNA card[FCOE])
i have found that using showing the flogi database im getting only the fc port in the outputs,but  my fcoe ports are not found.
can you please tell me what should i do /configure to fix the issue ?
and i have attached the show running config and show flogi database outputs for reference. please check
ARIQ
7 Replies 7
Ariq Ibne Aziz
BTEB-N5K(config-if)# show int br
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/9      1      auto   on      sfpAbsent        --     --           --
fc1/10     1      auto   on      sfpAbsent        --     --           --
fc1/11     1      auto   on      sfpAbsent        --     --           --
fc1/12     1      auto   on      sfpAbsent        --     --           --
fc1/13     1      auto   on      sfpAbsent        --     --           --
fc1/14     1      auto   on      sfpAbsent        --     --           --
fc1/15     1      auto   on      sfpAbsent        --     --           --
fc1/16     1      auto   on      sfpAbsent        --     --           --
fc1/17     100    auto   on      up               swl    F       8    --
fc1/18     100    auto   on      up               swl    F       8    --
fc1/19     100    auto   on      up               swl    F       8    --
fc1/20     100    auto   on      up               swl    F       8    --
fc1/21     100    auto   on      up               swl    F       8    --
fc1/22     100    auto   on      up               swl    F       8    --
fc1/23     100    auto   on      up               swl    F       8    --
fc1/24     100    auto   on      up               swl    F       8    --
fc1/25     1      auto   on      sfpAbsent        --     --           --
fc1/26     1      auto   on      sfpAbsent        --     --           --
fc1/27     1      auto   on      sfpAbsent        --     --           --
fc1/28     1      auto   on      sfpAbsent        --     --           --
fc1/29     1      auto   on      down             --     --           --
fc1/30     1      auto   on      down             --     --           --
fc1/31     1      auto   on      down             --     --           --
fc1/32     1      auto   on      sfpAbsent        --     --           --
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Por
t
Interface        Ch
Eth1/1        1       eth  access down    SFP not inserted            10G(D) --
Eth1/2        1       eth  access down    Link not connected          10G(D) --
Eth1/3        1       eth  access down    SFP validation failed       10G(D) --
Eth1/4        1       eth  access down    SFP validation failed       10G(D) --
Eth1/5        1       eth  trunk  up      none                        10G(D) --
Eth1/6        1       eth  trunk  up      none                        10G(D) --
Eth1/7        1       eth  trunk  up      none                        10G(D) --
Eth1/8        1       eth  trunk  up      none                        10G(D) --
Port   VRF          Status IP Address                              Speed    MTU
mgmt0  --           up     192.168.25.6                            1000     1500
Interface  Vsan   Admin  Admin   Status      Bind                 Oper    Oper
                  Mode   Trunk               Info                 Mode    Speed
                         Mode                                            (Gbps)
vfc5       100    F     on     trunking    Ethernet1/5              TF   auto
vfc6       100    F     on     trunking    Ethernet1/6              TF   auto
vfc7       100    F     on     trunking    Ethernet1/7              TF   auto
vfc8       100    F     on     trunking    Ethernet1/8              TF   auto
Interface Secondary VLAN(Type)                    Status Reason
Vlan1     --                                      down   Non-routable VDC mode
BTEB-N5K(config-if)# show flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/17           100   0x4f00c0  50:00:d3:10:00:aa:b4:05 50:00:d3:10:00:aa:b4:00
fc1/18           100   0x4f0100  50:00:d3:10:00:aa:b3:05 50:00:d3:10:00:aa:b3:00
fc1/19           100   0x4f00a0  50:00:d3:10:00:aa:b4:06 50:00:d3:10:00:aa:b4:00
fc1/20           100   0x4f0080  50:00:d3:10:00:aa:b3:06 50:00:d3:10:00:aa:b3:00
fc1/21           100   0x4f0060  50:00:d3:10:00:aa:b4:07 50:00:d3:10:00:aa:b4:00
fc1/22           100   0x4f0040  50:00:d3:10:00:aa:b3:07 50:00:d3:10:00:aa:b3:00
fc1/23           100   0x4f0020  50:00:d3:10:00:aa:b4:08 50:00:d3:10:00:aa:b4:00
fc1/24           100   0x4f0000  50:00:d3:10:00:aa:b3:08 50:00:d3:10:00:aa:b3:00
Total number of flogi = 8.
Can any one help me??
Is there anything specific I need to do at the host end ? My host is Windows server 2012 in Dell power edge R730 :(
check out
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/operations/n5k_fcoe_ops.html
HI
Its a big document and im really not sure from where to start. Can you be little specific please ?
Thanks for replying.
ARIQ
Problem found in CNA card of the HOST.
I swapped the CNA with a good one and after that flogi database showed the vfc.
Im pretty unlucky that among 4 servers i found 3 of them faulty !!!!
That's really weird. Usually depending on the CNA, say for example Emulex they usually have a app on the server to configure the FCoE configurations.
Glad you where able to figure out the issue.
