08-23-2019 04:04 AM
Hi Team,
We are using Nexus5548UP where ports 1-19 are ethernet and ports 20-32 are for FC now I want to use 2 additional ports for FC now my question is, can I use ports 14-15 for FC or is it a rule that the FC ports have to be contiguous as such I need to use only ports 18 and 19 for FC. I do not want to disconnect ports 18 and 19 unless it is absolutely required. However is it fine if we have ports14-15 in FC and ports 20-32 in FC on Nexus5548UP. Please clarify
Solved! Go to Solution.
08-25-2019 10:18 AM
Greetings.
Fibre Channel ports must be configured from the last port of the module.
Ethernet ports must be configured from the first port of the module.
If the order is not followed, the following errors are displayed:
ERROR: Ethernet range starts from first port of the module
ERROR: FC range should end on last port of the module
On the Cisco Nexus 5548UP switch, the 32 ports of the main slot (slot1) are unified ports. The Ethernet ports start from port 1/1 to port 1/32. The Fibre Channel ports start from port 1/32 backwards to port 1/1.
So yes, Ethernet is contiguous till the FC ports start and those continue to end of module.
Kirk...
08-25-2019 10:18 AM
Greetings.
Kirk...
08-27-2019 04:04 AM
Thank you Kirk that is what I thought. Thank you for confirming the same
