06-17-2014 01:06 AM
I have 2 MDS 9148 switches, from which i have to configure 2 ports in port-channel of each MDS switch. which is connected on Cisco Fabric Interconnect 6248UP. Whenever I configure port channel on MDS and same as on FI, the ports of both the devices gets down administratively.
I have enabled following features on MDS:
feature npiv
feature fport-channel-trunk
whereas the ports as configured as "nontrunking" as I have read that its shouldn't e trunk when NPIV is enables, because it was showing a error while creating a port channel as " port mode not compatible ".
Please guide me configuring the port channel.
Ninad
Solved! Go to Solution.
06-17-2014 05:06 AM
Did you enable F port channel trunking on UCS ? (I assume your UCS is in FC end host mode, NPV)
Note | If the fabric interconnects are configured for Fibre Channel end-host mode, enabling Fibre Channel uplink trunking renders all VSANs with an ID in the range from 3840 to 4079 non-operational. |
06-17-2014 05:06 AM
