Port-Channel configuration on MDS 9148 for FI
Ninad Thakare
Beginner
Beginner
I have 2 MDS 9148 switches, from which i have to configure 2 ports in port-channel of each MDS switch. which is connected on Cisco Fabric Interconnect 6248UP. Whenever I configure port channel on MDS and same as on FI, the ports of both the devices gets down administratively.
I have enabled following features on MDS:
feature npiv
feature fport-channel-trunk
whereas the ports as configured as "nontrunking" as I have read that its shouldn't e trunk when NPIV is enables, because it was showing a error while creating a port channel as " port mode not compatible ".
Please guide me configuring the port channel.
Ninad
Walter Dey
Advocate
Advocate
Did you enable F port channel trunking on UCS ? (I assume your UCS is in FC end host mode, NPV)
Enabling Fibre Channel Uplink Trunking
Note
If the fabric interconnects are configured for Fibre Channel end-host mode, enabling Fibre Channel uplink trunking renders all VSANs with an ID in the range from 3840 to 4079 non-operational.
Procedure
    Step 1  In the Navigation pane, click the SAN tab.
    Step 2  On the SAN tab, expand SAN > SAN Cloud.
    Step 3  Click the node for the fabric where you want to enable FC uplink trunking.
    Step 4  In the Work pane, click the General tab.
    Step 5  In the Actions area, click Enable FC Uplink Trunking.
    Step 6  If the Cisco UCS Manager GUI displays a confirmation dialog box, click Yes.
    Walter Dey
    Advocate
    Advocate
    Note
    Procedure
      Recognize Your Peers
