Remote Volume Mirroring - brocade 300 -> cisco MDS 9222i
abhiasabhi
I have connected brocade 300 to cisco MDS 9222i via 4 Gig FC interface. By connection diagram is as follows brocade 300 -> cisco MDS 9222i -> cisco MDS 9222i -> brocade 300. Two cisco MDS is connected to each other through 1 Gig Ethernet, FCIP tunnel is also being created using this 1 Gig Ethernet interface. Storage box is connected to the brocade switches at both ends. I want to test the remote volume mirroring between both storage boxes, for this I need to see both brocade switches under single fabric so as to zone their interface under single zone. Anybody can help me in this with cisco end & brocade end configuration?
maminhas
Depending upon the switch type , First check the interoperability matrix for which interop mode is suitable between MDS and Brocade switch.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/matrix/Matrix5.html
Then configure the required interop mode related step by step configuration.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/guide/ICG_brmc.html
