09-16-2020 11:03 PM
Hello!
I currently have MDS9148 SAN Switch. Zoning is already completed and Host can able to see the LUN. Due to some requirement, Host name is changed and the same changes I have to make in SAN Switch (Device-Alias and Zone name). Is there any way to make the changes without any impact to the host?
Thank you in advance for help with this issue!
09-16-2020 11:13 PM
RENAME ALIAS FOR HOSTS (vsan id of 10):
switch(config)# fcalias rename old-AliasName new-AliasName vsan 10
Ref:
09-17-2020 12:42 AM
Hi Jaton,
Thanks for reply. The link is related to fcalias rename however In the switch, "show fcalias" is not giving any output.
The command "show device-alias database", is showing the device alias name I have to rename.
09-17-2020 02:53 AM
So you are running on device-alias and not fcalias.
So you want to rename a device-alias:
switch(config-device-alias-db)#
device-alias rename Renames an existing device alias with a new name.
old-device-name new-device-name
09-17-2020 03:02 AM
09-17-2020 03:17 AM
I already tried this option "device-alias rename old-device-name new-device-name", however the new name is not reflecting in Zone name. For example, host name is host_HBA1 and the Zone name is host_HBA1_SAN3S. After changing the host name with above command from host_HBA1 to host2_HBA1, the same is not reflecting in Zone name (From host_HBA1_SAN3S to host2_HBA1_SAN3S). Do I have to remove the zone from zoneset and create a new zone with new name?
09-17-2020 09:52 PM
Any help will be highly appreciated.
09-21-2020 04:29 AM
You will have to rename zones with its own command.
https://community.cisco.com/t5/storage-networking/how-to-rename-zones-on-mds9513/td-p/2244828
Like:
zone rename ...
