05-21-2015 12:22 AM
Hello to the community,
I'm working on a SAN built by scratch using MDS switches and I need to integrate some brocade switches installed on bladecenters.
At first I decided to built two vsan, one for the "Cisco-only" vsan and one for the interoperable one to overcome limitations due to the interoperability mode.
Then I started configuring a pilot, following this document
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/guide/interopgd/ICG_brmc.html
and I discovered that interop mode 1 is the default for Cisco MDS.
What I understand now is that the only real limitation given to Cisco MDS by interoperability is the domain id, and that I can't use port channels, but only towards other vendor switches.
Is this correct? If it is, I suppose I'll use just one vsan.
Thank you very much and regards to all.
Denis
Solved! Go to Solution.
05-21-2015 05:28 AM
Hi Denis
my 2c; I would not recommend using any interop mode; interop mode 1 is the classical one, with almost zero Features.
Are you sure that Brocade still supports interop mode ? and if yes, how long ?
Your use case: why are you not using Brocade Switches in the blade Chassis with NPV mode, connecting them to MDS in NPIV mode.
This is industry Standard, and works ok
Walter.
05-21-2015 05:28 AM
Hi Denis
Walter.
05-21-2015 06:23 AM
Thank you Walter, I didn't think about NPIV, as I am not used to these interop issues.
But now I think I'll try it. Your recommendation sounds good to me.
Denis
