01-23-2015 08:27 AM
Is sfp CISCO-AVAGO SFCT-5798PZ-CS3 (it's 1 GE sfp) supported on Storage Node (SSN16) module on Cisco MDS9513 switch Director ?
If yes, short wave fc cable connexion or lon wave fc cable connexion ?
thanks
Abd
01-23-2015 11:44 AM
Hello Abdel,
The below are SFPs you can use for SSN-16 line card
01-24-2015 02:36 AM
Hi Vu Phan
01-24-2015 05:20 AM
I have already responded to your THREAD.
01-26-2015 02:42 AM
Hi Vu,
thanks so much for your answer. I'd like to give you more details on my problem. The cisco sfp avago is already pluged on the SSN16 module for 2 or 3 years ago but not used. We used only Copper sfp's for fcip distant connexions (connexions to Nexus). But now we have a new migration projet and we need GE FC connexion to Cisco ASR 1002-F which is connected to Colt DWDM.
Here is an exeample of the copper sfp we use and working very well. How to know if it's a DS-SFP-GE-T ??
MDS1COREDIDPA# sho int gigabitethernet 9/9 transceiver details
GigabitEthernet9/9 sfp is present
Name is CISCO-METHODE
Manufacturer's part number is SP7041-SBU
Revision is E
Serial number is MTC1446012Z
Cisco part number is
Cisco pid is
Nominal bit rate is 1300 Mb/s
Cisco extended id is unknown (0x0)
No tx fault, no rx loss, in sync state, diagnostic monitoring type is 0x0
Digital diagnostics feature not supported in SFP
Here is the sfp GE FC pluged we want to use. How to know if it's a DS-SFP-FCGE ??
MDS1COREDIDPA# sho int gigabitethernet 9/1 transceiver details
GigabitEthernet9/1 sfp is present
Name is CISCO-AVAGO
Manufacturer's part number is SFCT-5798PZ-CS3
Revision is 0000
Serial number is AGC1521ULFF
Cisco pid is
Nominal bit rate is 1200 Mb/s
Link length supported for 9/125mm fiber is 10.100 km
Link length supported for 50/125mm fiber is 550 m
Link length supported for 62.5/125mm fiber is 550 m
Abd
