12-04-2003 02:55 AM
Then I connect SunT3 to SN5428 in log I have only message :
"Dec 03 16:14:01: %FC-4-TopologyOperChange: TopologyOperChange;9;0;0;0" and nothig changes (port remain"Inactive").
I have default configuration on this port:
interface fc2 enable
interface fc2 ms-enable enable
no interface fc2 al-fairness enable
interface fc2 fan-enable enable
interface fc2 ext-credit 0
interface fc2 mfs-bundle enable timeout 10
interface fc2 linkspeed auto
interface fc2 type gl-port
interface fc2 rscn enable
What I need to do?
Thank you
12-04-2003 04:02 AM
Your message is from port FC-4, looks like your T3 is on port FC-2.
Is the T3 Fabric capable? you may need to configure interface FC-2 for fixed speed and fixed mode.
Use this set of commands below to select mode setting and linkspeed
int fc2 ?
al-fairness - Loop priority algorithm
default - Reset defaults on Fibre Channel interface
diag - Enable Fibre Channel diagnostics
enable - Enable Fibre Channel interface
ext-credit - Extend Credit
fan-enable - Fabric Address Notification (FAN)
linkspeed - Transfer rate on Fibre Channel interface
loopback - Initiate various loopback tests
mfs-bundle - Multi-Frame sequence (MFS) bundling
ms-enable - In Band Management
reset - Reset the interface
rscn - Fibre Channel Registered State Change Notification
type - Port type
12-04-2003 04:32 AM
Just a moment? What do you mean? In log all events from FC2 and FC3 interfaces are written "%FC-4-" and "%FC-5-". And SFP modules are intalled only in FC2 and FC3.
From log:
Dec 04 10:09:28: %FC-4-TopologyOperChange: TopologyOperChange;108;0;0;0
Dec 04 10:09:28: %FC-5-PortStateChange: PortStateChange;109;0;0;2;Online
Dec 04 10:09:33: %FC-5-PortOperChange: PortOperChange;110;0;0;2
Dec 04 10:09:46: %FC-5-PortOperChange: PortOperChange;111;0;0;3
Dec 04 10:10:02: %FC-5-PortOperChange: PortOperChange;112;0;0;3
Dec 04 10:10:17: %FC-5-PortOperChange: PortOperChange;113;0;0;3
Dec 04 10:10:55: %FC-4-TopologyOperChange: TopologyOperChange;114;0;0;0
Dec 04 10:10:56: %FC-5-PortStateChange: PortStateChange;115;0;0;2;Offline
Dec 04 10:11:01: %FC-5-PortOperChange: PortOperChange;116;0;0;2
Dec 04 10:11:22: %FC-5-PortOperChange: PortOperChange;117;0;0;2
I changed linkspeed to "1gb" - result negative.
I will try to change another default settings.
12-04-2003 05:29 AM
Ah.... your right 4 & 5 are the level of the message, there is 0-7 The port mode is changed via the Type setting. Has this array been plugged into a Fabric switch prior, or was it direct attached to a HBA?
12-04-2003 05:53 AM
We used Fabric hub prior.
