09-23-2016 07:18 PM
I'm trying to figure out if I can run raid 5 with four new ssd drives I have connected. The LSI Raid utility only shows raid 0,1 and 10 but raid 5 is greyed out. How do I get raid 5 option available. If raid 10 is supported why wouldn't raid 5 be?
09-24-2016 09:09 AM
see eg.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/raid/configuration/guide/RAID_GUIDE.pdf
Which Raid-Controller do you have
Yes2 |
Yes3 |
09-24-2016 10:19 AM
09-24-2016 11:36 AM
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C200M1/install/c200M1/RAID.html#98288
How to Determine Which Controller Is in Your Server
If no models of card are displayed but there is a RAID configuration, your server is using the
onboard ICH10R controller. You are also prompted to press Ctrl-M to launch the configuration utilities for this controller.
According to this, you are using the integrated controller ! and this is the reason, that raid-5 is not supported !
09-24-2016 05:29 PM
That's what I was afraid of. Control M brings up the LSI utility which shows Raid 0, 1 and 10 options.
