During check future upgrade MDS9148
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes non-disruptive reset
Images will be upgraded according to following table:
Module Image Running-Version(pri:alt) New-Version Upg-Required
1 system 5.2(2) 5.2(2d) yes
1 kickstart 5.2(2) 5.2(2d) yes
1 bios v1.0.19(02/01/10): v1.0.19(02/01/10) v1.0.19(02/01/10) no
Are we sure there ll no be any service interruption
Best regards
