06-23-2010 07:52 AM
I have a 9513 and a 9509 ISL'd in a single fabric. The Eports are in VSAN 2, and all the zones are in VSAN 1. ( I know this is not best practice, and is going to be fixed) Anyway, after making the 9513 the principle switch, and shutting down all blades in the 9509, VSAN 1 segments in Fabric Manager. I have done the following so far:
made the 9513 the principle switch
checked every zone in the zone set for VSAN 1 for discrepencies between what is contained in each switch. they are identical.
I don't know how to keep the VSAN from segmenting.
Can anybody help?
Bob
06-23-2010 06:39 PM
are you trunking VSAN 1 ?
06-24-2010 04:40 AM
No.. VSAN 1 is not trunked. VSAN 2 was at one time. VSAN 2
was used for the ISL Trunk between the switches. But that trunk has been deleted. Right now, in order to keep VSAN 1 from segmenting, i have a couple of cables running between the switches as Eports. But if i remove them, VSAN 1 will segment.
06-24-2010 06:21 AM
the only time i see vsan 1 segment when physical switch is connected to another switch and vsan 1 is not trunked. In your case it segments even when it's not connected to any other switches ?
06-24-2010 06:30 AM
Correct... there are only the 2 switches connected. And if i remove 9509, vsan1 segments..
06-24-2010 07:33 PM
have you run "show logging logfile" ..and see anything interesting that could be related to segmentation.
06-25-2010 05:45 AM
Yes.. when i deleted the ISL trunk and shut the ports between the switches.. this is the message that shows up:
2010 Jun 23 05:54:39 NPN-SAN-SW02 %PORT-5-IF_TRUNK_DOWN: %$VSAN 1%$ Interface fc1/1, vsan 1 is down (Gracefully shutdow
n)
it is shutting down VSAN 1. i'm wonderig if it is just a simple matter of brining VSAN 1 back up...
06-25-2010 07:23 AM
worth a shot
07-09-2010 04:47 AM
I got it fixed.. IT ended up that Fabric Manager was just being stupid. When i was removing the switch from the ISL partnership, fabrci manager was still seeing both sets of zone sets and interpreting that as a "segmented VSAN". All i had to do was remove bot hswitches from fabric manager and then rediscover just the remaining switch. problem solved...
Thanks for you help!
Bob
