access port change blocks other port
natxo asenjo
hi,
This is my first post here. I recently bough for a home lab a sg300-10 switch. I have enabled layer 3 routing on it and have come across a puzzling issue. The switch is the default gw on this network, and in front of the switch there is a cable modem (
ip route 0.0.0.0 0.0.0.0 192.168.0.7).
This is my config:
config-file-header
switch5ed948
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.0.120
ip dhcp relay enable
ip dhcp information option
no bonjour enable
hostname switch5ed948
no passwords complexity enable
username cisco password
snmp-server server
clock timezone " " 1
clock summer-time web recurring eu
sntp unicast client enable
sntp unicast client poll
sntp server 192.168.0.120
ip telnet server
interface vlan 1
no ip address dhcp
interface vlan 10
name LOM
ip address 192.168.10.254 255.255.255.0
interface gigabitethernet7
switchport mode access
interface gigabitethernet8
switchport access vlan 10
Quite simple. On gi7 and gi8 I want to configure 2 LOM (lights-out-management) interfaces of 2 devices in vlan 10.
When I enable vlan 10 on gi7, I lose network connectivity to devices behind gi5 which is a trunk port vlan 1. Very strange
So I just want to use 2 ports as access ports on a not standard vlan. These ports should not be trunk/general ports, just plain access ports.
What am I doing wrong here?
TIA,
natxo
Natxo, this is how it should work-
interface vlan 1
ip address 192.168.0.254 255.255.255.0
interface vlan 10
Host A resides on a port that is a member of vlan 1. Host A NIC configuration should be-
IP 192.168.0.x
Mask 255.255.255.0
Gateway 192.168.0.254
Host B resides on a port that is a member of vlan 10. Host B NIC configuration should be-
IP 192.168.10.x
Mask 255.255.255.0
Gateway 192.168.10.254
Now, if Host A and Host B are both able to respond to ICMP then there should be no problems to ping either direction. Also, make sure if either of those computer have wireless access to turn it off.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
7 Replies 7
Tom Watts
Hi Natxo, you need an IP address on the vlan interfaces (SVI). Without the IP address on the vlan interfaces, it is a layer 2 vlan and won't route traffic between the vlans.
If you perform
show ip route
You will see there is no routes to route between vlan. If you add the IP address to the vlan then do another show ip route, you will observe it will dynamically build so long as there is an active connection within that vlan.
-Tom
hi Tom, thanks for your (very fast!) reply.
# show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding:          enabled
Codes: C - connected, S - static, D - DHCP
S  0.0.0.0/0          [1/1] via  192.168.0.7  2:23:11              vlan 1
C  192.168.0.0/24     is directly connected                        vlan 1
C  192.168.10.0/24    is directly connected                        vlan 10
Vlan 10 has an ip and it's enabled. I can ping it from the switch or outside the switch. I can put gi8 on vlan 10, but the second I type switchport access vlan 10 for gi7, I lose connectivity to the network behind gi5 which is just a standard trunk vlan 1 port (standard config).
Losing this connectivity means I lose access to my dns server, so it impacts my internet activiity ;-)
Can you show a correct running config? The sample output on the original post does not show an IP address on the vlan 7, nor does it show a vlan 7 is even created.
Matter of fact, vlan 1 also does not have an IP addressed assigned to it.
You need IP addresses on whatever vlan interface you want to route locally through the switch.
-Tom
HI,
The full config (except for the password) is on my first post ;-)
I do not have a vlan 7, I have vlan 1 and 10.
It's true vlan 1 does not show an ip address, this is apparently the way the web ui configures it. I have manually added it now.
The problem arises when configuring gigabit ethernet 7, not vlan 7.
I post the full running-config again:
config-file-header
switch5ed948
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 10
exit
no bonjour enable
username cisco password encrypted
snmp-server server
ip telnet server
interface vlan 1
no ip address dhcp
interface vlan 10
name LOM
I hope it is clear now ;-), my apologies for not being clear before.
to llustrate what I mean, I open a ping to 192.168.0.120. Then I change the vlan for gi7:
#configure terminal
switch5ed948(config)#interface GigabitEthernet 7
switch5ed948(config-if)#switchport access vlan 10
I miss some pings:
64 bytes from 192.168.0.120: icmp_seq=52 ttl=64 time=2.60 ms
64 bytes from 192.168.0.120: icmp_seq=53 ttl=64 time=2.75 ms
64 bytes from 192.168.0.120: icmp_seq=58 ttl=64 time=2.75 ms
64 bytes from 192.168.0.120: icmp_seq=59 ttl=64 time=1.29 ms
64 bytes from 192.168.0.120: icmp_seq=60 ttl=64 time=2.58 ms
64 bytes from 192.168.0.120: icmp_seq=61 ttl=64 time=2.61 ms
64 bytes from 192.168.0.120: icmp_seq=62 ttl=64 time=2.59 ms
Between icmp_seg 53 and 58 I changed the vlan setting back and forth.
interface vlan 1
interface vlan 10
IP 192.168.0.x
Mask 255.255.255.0
IP 192.168.10.x
Mask 255.255.255.0
-Tom
hi,
well, the problem was the cables were incorrectly labeled :-(
I found out running show arp and finding out the hardware addresses I thought were on interface 2 were in fact in 7 and the other way round.
Operator error. Thanks for your hints and excuses for wasting your time.
