All TLV's sent by LLDP
Specifically, I have a customer who is looking for a TLV that would have all the available Vlans allowed on a specific interface.
Martin Aleksandrov
This is supported on SG250/350/550 series switches. You can enter the TLVs that are sent in the LLDP Protocol Data Unit (PDU). The LLDP-MED TLVs to be advertised can be configured through LLDP-MED Port Settings, and the management address TLV of the device may be configure. The 802.1 optional TLVs include:
- PVID — Port VLAN ID advertised. This feature is disabled by default.
- PPVID — Protocol Port VLAN ID advertised.
- VLANs — The VLANs that will be advertised.
- Protocols — The protocols that will be advertised.
For more information you can visit the following link: https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5578-configure-link-layer-discovery-protocol-lldp-port-settings-o.html
Thank you for the reply. Would you happen to know if the same option is available on the Nexus 93180's?
The Cisco Nexus 9000 NX-OS system (release 7.0) does support LLDP which advertises the following TLVs by default:
  • DCBXP
  • Management address
  • Port description
  • Port VLAN
  • System capabilities
  • System description
  • System name
Those are all configurable. More information you can find at https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_...
Martin
