06-17-2014 08:52 AM
There are numerous alerts on the Cisco SG300 Management Switch. This is in Layer 3 mode.
The alert is: %ARP-E-ARPTBL: ARP Table Overflow, aggregated
I cannot add an additional Static route either unfortunately with the following alert message:
%IPROUTETABLE-A-ROUTETABLEOVERFLOW: IP routing table overflow: failed to add route address
Is there some limitation on the switch?
Thanks in advance.
Sam
08-08-2014 12:03 PM
Try changing the maximum entries under routing resources (TCAM utilization) from Use Default to some higher number in the user defined option. I believe the default is 128.
10-24-2014 06:16 AM
Worked for me, thanks!
