assign switch ports not in use to an inactive VLANs
yaredo70
Hi All,
The note is from Cisco switch STIG requirement that I need to implement in all my switches in the network.
Rule Title: The Cisco switch must have all disabled switch ports assigned to an unused VLAN.
Discussion: It is possible that a disabled port that is assigned to a user or management VLAN becomes enabled by accident or by an attacker and as a result gains access to that VLAN as a member.
Check Text: Step 1: Review the switch configurations and examine all access switch ports. Each access switch port not in use should have membership to an inactive VLAN.
interface GigabitEthernet0/0
switchport access vlan 999
shutdown
interface GigabitEthernet0/1
shutdown
interface GigabitEthernet0/9
shutdown
Step 2: Verify that traffic from the inactive VLAN is not allowed on any trunk links as shown in the example below:
interface GigabitEthernet1/1
switchport trunk allowed vlan 1-998,1000-4094
switchport mode trunk
Note: Switch ports configured for 802.1x are exempt from this requirement.
If there are any access switch ports not in use and not in an inactive VLAN, this is a finding.
Fix Text: Assign all switch ports not in use to an inactive VLAN.
Step 1: Assign the disabled interfaces to an inactive VLAN.
SW3(config)#int range g0/0 – 9
SW3(config-if-range)# switchport access vlan 999
Step 2: Configure trunk links to not allow traffic from the inactive VLAN.
SW3(config)#int g1/1
SW3(config-if)#switchport trunk allowed vlan except 999
My first question is, how can I check that the switch has already been configured with trunk links to not allow traffic from the inactive VLAN?
second question - what would happen if I configured the port with the below command?
@yaredo70
"My first question is, how can I check that the switch has already been configured with trunk links to not allow traffic from the inactive VLAN?"
show interface trunk   - This command will list all the interface in trunk and the vlans on it.
With this command you would add the interface from Gi0/0 to Gi0/9 to vlan 999
 You can also use the command  "switchport trunk remove vlan 999"
