01-13-2019 04:45 AM
Hi, People
How do i make to show bandwidth of an interface ?
Solved! Go to Solution.
01-13-2019 04:49 AM
Show interface command shows properties of the interface : (Here is the sample output).
SW1#show interfaces ethernet 0/0
Ethernet0/0 is up, line protocol is up (connected)
Hardware is Ethernet, address is aabb.cc00.1000 (bia aabb.cc00.1000)
Description: SW2
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, media type is RJ45
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 8000 bits/sec, 14 packets/sec
1784277 packets input, 127727075 bytes, 0 no buffer
Received 104027 broadcasts (0 multicasts)
9601166 packets output, 667775068 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
01-13-2019 04:49 AM
Description: SW2
