Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3444 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4994 Views
  • 1 replies
  • 16 Helpful votes
Hi,  Is it possible to connect SG350X-48 using all four SFP+ ports to create a 40gb uplink to a C9500 core?This is a multicast-only network with many C9300's all with 40gb links to the c9500 but for this instance we had to spec a SG350 because it's l...
seanl0004 by Level 1
  • 658 Views
  • 3 replies
I'm working to configure some new SF300-08 switches.  They are at firmware 1.4.10.6 which I believe is the latest release.One of them is working fine.  The other, fresh out of the box, updated firmware with the http interface OK but is acting strange...
fmarshall by Level 1
  • 980 Views
  • 3 replies
Resolved! RV34x China model
I currently have an RV340 working work here in the US. I want to buy an RV34x for my office in China. I am wondering if there are huge differences apart from PID? For example I don’t see SSL VPN listed for the China model and honestly my Chinese is p...
alphaod by Level 1
  • 1057 Views
  • 4 replies
Hello,I have updated my SG200-26 to the latest Firmware 1.4.10.06 and did a factory reset and rebooted. When I connect the network cable into it and my laptop to it my laptop can't get to the rest of the network. From the laptop I can log into the sw...
SomeITGuy by Level 1
  • 1153 Views
  • 5 replies
Hello! As title say I have a question about upgrading this switch, I am not an IT guy, but i need to do some kind of work about it, and is my first time with managed switches, so in my family business, we got this switch when my family installed the ...
CesarSM by Level 1
  • 910 Views
  • 2 replies
Hi,Recently i have an issue, i brough the SG250-08 port, but it not come with any mounting kit, and also no part available for me to order for rack mounk kit, can advise on the SKU for the 8 port rack mount? Thank you.
On firmware 2.5.0.78, as well as on 2.4.5.71, there is a discrepancy between the creation time of files in the file directory menu. Practically it was possible to find out that, for example, the Operation Type Dublicate Running configuration in Start...
Duber by Level 1
  • 744 Views
  • 0 replies
On firmware 2.5.0.78 as well as on 2.4.5.71 in the GUI there is no possibility in the manual settings to specify the default gateway. This feature is only present in the Getting Started Wizard.Or, alternatively, specify the gateway through the CLI. P...
Duber by Level 1
  • 5380 Views
  • 0 replies
  • 5 Helpful votes
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
