Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2605 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7243 Views
  • 4 replies
  • 17 Helpful votes
Hello all,i have a SX550x All is ok on 10gbe, but i recently connect a 2.5gbe card and i see only 1gbe...My question is stupid but is it normal? If yes, i need another swith compatible 1, 2.5, 5 and 10gbe?thx a lot
Ladies/Gents:I need to change the management IP of my 9300. Discovered I have a C1000 connected on the network with duplicate IP address. Should start out by asking if I can do this via the CLI interface on the switch web GUI or can this only be acco...
I just deployed a CBS250-16P-2G in an office environment and the (what I am pretty sure is) transformer noise is pretty bad. Its a continuous high pitched buzz and the users near it are being driven crazy. I am probably going to seek replacement, but...
brendan by Level 1
  • 2518 Views
  • 4 replies
The 3850 has had the following commands completed:install remove inactiveThen going to the desktop hosting the Solarwinds TFTP server.I was able to ping the switch from the desktop.When I start the remove function, I get the following:SUCCESS: No ext...
StarLog by Level 1
  • 1038 Views
  • 7 replies
Hi All,I am trying to configure a script for saving the running-config to a fileserver for backup purposes. So, it must be able to run without user interaction and that a user must not be logged on the specific server where the script is running. I h...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
