Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2978 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4567 Views
  • 1 replies
  • 16 Helpful votes
Hi,   I have an SG 200-08 updated to the latest 1.0.8.3 firmware.   The device is configured like so:   Interface g1 configured as Trunk mode with PVID 61. There's also a tagged VLAN (50) configured on this interface.Interface g2 configured as Access...
techstone by Level 1
  • 775 Views
  • 0 replies
Hello, I have sg300-52 with firmware 1.4.8.6 .I installed MGBLX1 sfp module, but i didn't see it in Administation - Diagnostic - Optical Module status or  by command "show fiber-ports optical-transceiver".There are only ComboC ports in Port managemen...
Please, We need to know the thermal dissipation power for small business switches SG110 series (in BTU, Watt, or whatever unit). Speciffically to the following models: * SG110-24 * SG110-24hp It is really important to us in order to achieve a thermal...
HI all. I have two sg200 series switches and a Cisco ASA 5505. I bought the switches a few years ago and stuck them together on layer 2 for simplicity's sake, but now, for fun, I'm converting my flat network to a L3 network. I still have my layer 2 s...
Lee Wade by Level 1
  • 1112 Views
  • 4 replies
Hi I'm currently running a Cisco SG300-28 28 port Gigabit Managed switch, when I try to upgrade the firmware it gives an error: copy:SW code file is over sized. Can anybody assist? Regards Emmanuel
jhb by Level 1
  • 1446 Views
  • 5 replies
I have 3 AP-571, 1 RV320 and 1 SG300-28MP.   My APs have two VLANs 1 & 50 with 50 being tagged on both ports although only one connection. My RV320 is has no DHCP servers but set to relay to my SG300 SVLI's.   My SG300 is my dhcp server and in L3 mod...
viningele by Level 3
  • 3824 Views
  • 2 replies
This weekend I was updating my switch.  Uploded firmware and then set it to Layer 3 mode from ssh:    set system mode router But alas, the switch wont come back alive. I've tried 30-30-30 and I see lights flash but only briefly and then nada.   I thi...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
