Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1495 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2934 Views
  • 1 replies
  • 15 Helpful votes
Hi, I have setup a SG300 (in L3 mode) as below but can't solve what I thought should be a simple problem, but cannot for the life of me figure it out. PC1 and PC2 can ping each other and 192.168.1.100 (port GE1). So I'm happy that VLAN setup and DHCP...
Simon DM by Beginner
  • 325 Views
  • 1 replies
こんにちは。SG300-20JPを6台所有しています。 fw-1.4.5.02、boot-1.3.5.06 で統一しています。 うち1台だけ Green Ethernet > プロパティ の画面で 802.3 Energy Effcient Ethernet (EEE) のチェックボックスが存在しません。 試しにCUIで接続し、#show eeeと打ち込んでも Unrecognized command と返されます。 Green Ethernet > ポート設定では、ポート設定の編集ポップアッ...
vsmadoka by Beginner
  • 400 Views
  • 0 replies
hi, i recommended a Cisco switch for my workplace because i learnt it was the best. they finally brought in SF 100-24 (small business) switch. but the problem is that i cant seem to configure and work with it at all. when i connect the computers thro...
kivoo4all by Beginner
  • 329 Views
  • 1 replies
Hello, So, I just got a SF300 switch for our small business. I am trying to configure it but i am a little confused. I have set the switch to layer 3 mode and accessed it through the CLI. I have created a new VLAN and assigned it all 24 Fa ports, I ...
Hi All, I've am not that advance level user of Cisco WLC but I have recently deployed (Dynamic VLAN) wired network security with cisco switches. The same I need to configure with Cisco WLC 2504 using the existing VLANs created in my network.  Scenar...
Hi,I have upgraded my SG200-08 switches from firmware version 1.0.5.1 to version 1.0.6.2. Since that new firmware is active, the network-printing from my Macbooks and iMacs is not working anymore. They all have TCP/IP connected network printers (not ...
RMBaltzer by Beginner
  • 25678 Views
  • 106 replies
