Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2944 Views
  • 1 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7498 Views
  • 4 replies
  • 17 Helpful votes
We are using two SG500-52 switches in a stack, in L3 system mode and with the latest firmware 1.4.1.03.The stack of switches is connected with 2-port LAGs to ESXi hosts. One port of the LAG is on Master switch, the other one is on Backup switch.LAGs ...
Levi9Cisco by Frequent Visitor
  • 1802 Views
  • 5 replies
Ok. I have one for you. Everything is working at the moment but not working how I thought it would.   I have a SG300-52MP that I configured first. Smartport, dynamic voice vlan disabled, LLDP, CDP enabled as default. vlans are 1,10,20,30,40,50,60,70,...
Cypher720 by Community Member
  • 1472 Views
  • 5 replies
Hi, all!   The main reason why I'm open the topic - can't connect to switch, I don't know its IP and I can't find it, despite I'm connected directly to ethernet port. I tried to find IP by LanScope or WireShark. Also, I tried to connect by standart C...
Trubolex_ by Community Member
  • 2241 Views
  • 7 replies
hi, in sg500 default all ports in native vlan are trunk. i have configured 2 vlans and set all ports as access. To connect switch with second switch i need one trunk port . Should i change all other ports to access in native vlan ? Do you create a  l...
Mk11 by Community Member
  • 1793 Views
  • 1 replies
I have two SG300-28P (SRW2024P) switches and one seems to be dead.  When plugged in, the fans turn on, the power comes on, and the port LEDs light for a split second just like it is supposed to do.  But, there is no console response and one, sometime...
CwdOnCisco by Community Member
  • 908 Views
  • 1 replies
I worked as an IT Admin in a school and we have to renew our L3 switches.   I have used previously in some little sites SG300-52 or 28 and i know the TCAM ressources are limited (around 500 entries if i remember).   I'v difficulties to find these val...
epersan by Community Member
  • 1996 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
