Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3444 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4994 Views
  • 1 replies
  • 16 Helpful votes
Dear All, I have a PoE switch model "SG300-28PP 28-Port Gogabit PoE+ Managed". I want to use this switch with ePMP AP and also ubnt Nanostation radio. Initially  I have tried but nothing to do. Below the configuration information. Please help me if ...
I am getting this alert every second. It is slowing my server down to  a crawl. Alert%HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x1214 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset   Any help is appreciate...
keith by Level 1
  • 780 Views
  • 3 replies
Hello, i need help to solve problem with fan control. Sometimes, once per day, the switch start to run fan at full speed. I understood it can be when temperature increase. But running this full speed all the time, only power off helps. Thank you, Mar...
delikomat by Level 1
  • 4688 Views
  • 4 replies
Hello community, I've problems to boot the switch with the running config. System Operational Mode:  L3 Mode     System Description:             SG300-20 20-Port Gigabit Managed Switch     Firmware Version (Active Image):     1.4.7.6Boot Version:    ...
hello experts,  i am not an expert on Cisco Switches, so i am using the web-gui to setup my switch. i have created an IP range for my network and also defined a different default VLAN - as i understand this to be 'best practice'. my default VLAN:199i...
Hello I have an Cisco SG-200-50 Switch and i have a problem with the LACP configuration. Actually I have an HP ProCurve 1800-24G Switch and here I configure LACP. On my PC (Windows 10) I have already activatet Teaming / LACP. All works fine. Th...
athlonk7 by Level 1
  • 835 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
