Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 581 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5541 Views
  • 1 replies
  • 16 Helpful votes
Hi,I´ve noticed a strange behaviour on my new SG500-28 stack ( 2 devices ). During node reboot ( console reload slot 1 / 2 ) the switch ports of the booting switch stay up ... I mean the device on the other side sees a physical link ...Can someone pl...
itservice by Level 1
  • 471 Views
  • 0 replies
i have one cisco switch 350 XG and 6 switches SF 300 and i created Vlan for each swith and than all this switches connect to switch 350 XG i already created Vlan interface for each Vlan. and elso enable IP routing on the mulitlayer switch . but there...
Try to recover the password on the switch...  was able to get to  switch(boot)> admin-password password but when I try to load the IOS.img (m9100-s2ek9-mz.3.3.lc.bin---> load bootflash:ios.img I got an error. no file found.... Please help.
moe891081 by Level 1
  • 493 Views
  • 0 replies
Hi,can somebody tell me how to configure the stacking of 2 SG350XG so that the current stack master stays stack master?I mean when I reboot or disconnect the current master from power the backup unit becomes master but at the moment this disconnected...
  • 620 Views
  • 0 replies
I have been successful at upgrading my firmware to 1.3.7.18 on my SG200-50, but it seems that I must upgrade the boot version from 1.1.0.6 in order to upgrade the firmware any further.  If this is so, can someone please tell me how to do this in very...
afreemanmd by Level 1
  • 10071 Views
  • 10 replies
My sg300-28 28 port gigabit managed switch SW version    1.3.0.62Boot version    1.1.0.6 Like to upgrade higher versions 1.3.5. can i update the boot ver and fw version directly to 1.3.5., Also the time taken to reboot the switch.
sushindms by Level 1
  • 678 Views
  • 0 replies
Hi! I use the SG300 in Layer 3 mode so it routes between VLANs. I have multiple VLANs and want to isolate some of them. E.g. I have VLAN 10 which is 192.168.0.x Therefore I create an ACL and an ACE which shall allow only traffic from the same VLAN, s...
Anguel by Level 1
  • 806 Views
  • 0 replies
Current version of cisco switch SG300-28 28-Port Gigabit Managed Switch is 1.3.0.62 fw, 1.1.0.6 boot version. I like to upgrade boot version to 1.3.5.58. Can i upgrade the boot version directly to 1.35.58 ? Is there any problem ? Any idea about the t...
  • 605 Views
  • 0 replies
Hi there,I just have a quick question to confirm that I have choosen the right Switch for what I want to do with it so it would be great if one of you could help me with that.I want to create a Stack with two Switches and configure a couple of VLANs ...
  • 684 Views
  • 1 replies
Hello, i have some SG500 in a stack.The Stack has Routing enabled and everything works as expected.But now i created a new VLAN10, assigned an IP-adresse and i'm not able to route into this vlan.There is no entry in the routing table. In VLAN10 are 2...
All, I am part of the CUCM TAC team and please bear with me as I do not handle much of the networking/switching aspect and really have no clue when it comes to the switches I am asking about. I've done some research and I can only find documentation ...
dgrup by Cisco Employee
  • 1741 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
